Bottom layer keeps printing a bad spot
dartronix
(@dartronix)
I am trying to print a 5.2 x 4.2 box. Every time I print the box, I get a bad area on the print on the first few layers. The inside files over it fine but the exterior looks like the attached picture. The material is PETG, first layer bed temp is 80C and then drops to 75C. The hot end is 240. Overall the print comes out great except for this one area. It repeats the problem every time I run the print. I checked the slicer layers and it doesnt show the issue, it shows a smooth print. I tried a concentric fill, and it did a similar issue. Instead of printing the bad layers, it jumped outside the perimeter of the build, printed a few layers in a 2" circle and then came back into the print and everything was fine.
Any ideas?
Postato : 21/11/2022 11:25 pm
RandyM9
(@randym9)
RE: Bottom layer keeps printing a bad spot
Have you tried printing this object in another location on the print sheet?
Same problem, same place?
Have you tried rotating the model on the bed?
Could be as simple as a fingerprint on the build plate.
I would start the print at 85* then increase to 90* for PETG.
Cheers
Postato : 22/11/2022 5:01 am
