Best way to store the Steel Sheet's ?
KalleKnall
(@kalleknall)
i have several steel sheet's of all three kinds.
Is it recommended to store the sheets into the bubble wrap or better without any covering ?
Is temperature or huminity a Problem or direct Sunlight ?
THX
KalleKnall
Napsal : 11/02/2022 9:27 pm
RE: Best way to store the Steel Sheet's ?
There is a bunch of steel sheet holders on Prusaprinters.org you can print.  No need to put them in bubble wrap. I'd only be concerned if I were in Panama with 90% humidity all the time, otherwise you're good.
Napsal : 12/02/2022 12:49 am
Your biggest enemy is rust. Basically, just keep them dry.
Napsal : 12/02/2022 1:20 am
