Bad adhesion after SUPER clean
luis.d3
(@luis-d3)
Hello,
I'm just a starter, but I'm already suffering after few prints.
I have the printer for 1 month now. And until now I just made few and simple printings. On the beginning everything fine.
Now I'm suffering. I cannot do a simple print. PLA is not adhering. This is happening ->
I clean the board(room temperature) with alcohol 96%
I tried to change Z. Board temperature 50/60. PLA temperature 205/215
But I'm still stuck. Any advice?
Best regards
Luis
Respondido : 02/05/2018 6:53 pm
reid.b
(@reid-b)
Re: Bad adhesion after SUPER clean
There are many threads here about that... read up. First suggestion- get your Z-height correct. It needs to be lower judging from your picture.
Next- New PEI sheets need careful attention to cleanliness until they get "broken in". Clean that PEI with dish soap and hot water. Dry and leave it alone. 91% IPA is fine for cleaning between jobs, but start with dish soap as it will clean any residual organics a lot better than IPA. And use a new paper towel with IPA... not a cotton rag.
Respondido : 02/05/2018 6:59 pm
michael.a35
(@michael-a35)
I don't think this is the bed at all personally. I would bet on z height being too high.
Did you calibrate your z-height as shown in the printing handbook?
Respondido : 02/05/2018 10:34 pm
luis.d3
(@luis-d3)
Hello reid,
thanks for your reply.
Actually I searched before posting, but in my perception PEI was very clean. That's why I didn't found an answer.
Tomorrow I will try your tips and report back.
Thank you for the support.
regards
Respondido : 02/05/2018 10:51 pm
Kwaad2
(@kwaad2)
I agree. Z-height is your issue.
I use Windex to clean my PEI sheet between prints. I used to have adhesion issues.
Hi, I'm Sean. I used to work on CNC machines.
I try to not make mistakes, but the decision is YOURS.
Please feel free to donate to my filament/maintance fund.
Respondido : 02/05/2018 10:52 pm
luis.d3
(@luis-d3)
Hi Michael, hi Sean
Yes. I did the Z calibration, and I tried manually decrease Z, without any success.
Tomorrow I will do new deeply testings, and report back.
Thanks for the support,
regards
Respondido : 02/05/2018 10:55 pm
justin.s18
(@justin-s18)
Many beginners think the first layer lines shouldn't squish into the bed, when the opposite is true. None of your lines look like they are squished at all, you need to get your Z value down (larger negative number). Most people end up around -.4 to -.6ish
Respondido : 02/05/2018 11:03 pm
Seriouslee
(@seriouslee)
Hello reid,
regards
even though alcohol removes grease, it does not evaporate without residue, it leaves behind a very thin layer of hydrocarbons, which adds up with each application and can negatively influence bed adhesion. i would suggest you try dish soap, scrub it down with a soft sponge, rinse it with a lot of water, dry it off with a lint free cloth or microfiber, and do not touch it with your fingers after that. after that you can use after a print your alcohol again to degrease your printbed. but like i said, alcohol isnt really cleaning it.
for pla you can boost your bed temperature from 60 to 70°c for the first layer
Respondido : 03/05/2018 12:48 am
Skulbl4k4
(@skulbl4k4)
Hi, try just the 3dlac it's perfect. The best adhésion spray and very low cost. I use it every day for my mk3 and is cleanable with hot water.
https://www.3dware.ch/3DLac-Adhesion-spray-En.htm
Respondido : 03/05/2018 2:45 pm
Nikolai
(@nikolai)
No need for expensive, special stuff.
As already mentioned here, adjust your Z-height. Your layer is too high.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 03/05/2018 7:29 pm
matthew.m34
(@matthew-m34)
OP,
Could you post a couple things? First, a picture of your PINDA probe's height relative to the cooling nozzle? And what is your Live-Z height right now? From the image your first layer is not close enough to the bed. Mine ended up being around 0.8mm or 0.9mm, but it's going to be different for everyone. It took some playing with to get the PINDA probe the right distance from the nozzle.
Respondido : 03/05/2018 7:58 pm
