Are there any custom 4-point bed trays? Will we ever get any?
Viccroy
(@viccroy)
After owning a Prusa MK3s for almost a month now I started noticing some bed wiggle.
I was wondering why Prusa3D does not offer a standalone 4 point bed tray?
From my perspective, I think it would actually help with making the bed assembly even more reliable.
Napsal : 31/05/2020 4:48 am
Agkirk
(@agkirk)
RE: Are there any custom 4-point bed trays? Will we ever get any?
Mine rattles noticeably when I do Hilbert patterns.  I think it is the right hand single bearing being loose.  Probably needs another turn on the u-Bolts but that appears to require a complete heat plate removal. Putting that off because it is printing so well.
Napsal : 01/06/2020 12:03 pm
Andrew
(@andrew-5)
1agkirk2
You don't need to remove the bed.  You can print a slotted spanner the correct height to get in or simply cut a bit of sheet metal to the correct face to face for the wee capture head nuts. They are not meant to be super tight so you don't need a highly tempered tool.
Andrew.
Napsal : 01/06/2020 1:59 pm
Peter in Katy
(@peter-in-katy)
@1agkirk2
If you are going to remove the bed, print out some bearing holders before you do.  Replace the u-bolt with something better.
The u-bolts are just a bad idea.
Napsal : 01/06/2020 5:05 pm
Agkirk
(@agkirk)
@andrewld
Thanks for the suggestion.  I found this on Thingverse and it printed perfectly in PETG and was just the right length and thickness.  Each Nylock got a quarter turn and the Hilbert pattern test will start shortly.
https://www.thingiverse.com/thing:13064
Napsal : 01/06/2020 7:04 pm
Agkirk
(@agkirk)
@peter-k42
Is this the bearing mount you were thinking of?
https://www.prusaprinters.org/prints/10429-prusa-i3-mk3-y-axis-bearing-strap-beefier-remix/files
Napsal : 01/06/2020 7:17 pm
Peter in Katy
(@peter-in-katy)
I'm sure those are fine.
I use these since I'm using the Bear X-Axis and frame.  You'd probably need the half upgrade, since I assume you've still got the Prusa frame.
https://www.thingiverse.com/thing:2823171
Edit:  I actually did print (and still use) the half upgrade when I upgraded the bearing last summer.  Just make sure you use PETG and follow all the suggestions Gregoire notes on the page.
This post was modified před 6 years by Peter in Katy
Napsal : 01/06/2020 10:00 pm
