Anyone Living in the San Diego area?
Tom R
(@tom-r-2)
Hello:
Anyone living in the San Diego area who would be open to tune my new printer.
It became out of sink during the shipment.
Tom
Tom Rauscher
Veröffentlicht : 17/03/2021 4:45 am
dorf
 dorf
(@dorf)
RE: Anyone Living in the San Diego area?
Hey Tom, great name! I'm in SD and just got my MK3S+ up and running (it arrived a few days ago). Still dialing it in, but it's printing well. What issues are you having?
Veröffentlicht : 18/03/2021 3:31 am
Tom R
(@tom-r-2)
@dorf
Hello:
The current issue is nothing will stick.
I am running the "First Layer Cal" in calibration and the print fails every time because it does not stick to the bed.
I try fining tuning it as it is printing but the print either moves around the bed or the filament bunches up under the needle.
Any suggestions.
Tom Rauscher
Veröffentlicht : 18/03/2021 1:19 pm
If nothing is sticking, it's likely you have adhesion issues. This can happen if your PEI print surface is contaminated. If you unwittingly touched it during initial assembly, this is very likely at least part of the problem. Please clarify which sheet you have: Smooth, satin, or textured. Here's an info dump for anybody new to the Prusa printers...
Your underlying issue is bed adhesion. This is a common problem that can be caused or aggravated by two factors that need to work together well for successful prints.  Filament should lay down cleanly on the PEI print surface and hold throughout the print. There are 2 main causes of bed adhesion issues: PEI cleanliness and Live-Z height adjustment. Even if you're dubious that these are the cause of your problems, they're 2 fundamental troubleshooting steps that you need to complete to rule out the basics:
  • A dirty PEI print surface. Even if you don't think this is the cause, it's always a good idea to make sure your PEI surface is clean before trying any other fixes. If it's a smooth PEI sheet, take it to the kitchen sink and give it a good dunk with Dawn (original formula, no vinegar or hand softener variants) dishwashing soap or your local equivalent (e.g. Fairy in UK). Use a clean paper towel to clean it off, and another to dry it. Avoid using any sponge or cloth that has been in contact with grease. Above all else, avoid touching the PEI print surface. Once it's good and clean, you should be able to use 91%+ isopropyl alcohol between prints, 100% acetone when that fails , and another dunk when acetone fails. Worst-case, use a 3M 7445 ScotchBrite (1200-1500 grit) pad or equivalent on smooth PEI to give it a very light buff, but only infrequently. If you've got a textured powder-coated PEI print surface, the official instructions are to use 91%+ isopropyl alcohol on it only. Rumors persist that some have had good luck getting started with these sheets by giving them a wipe with 100% acetone and a dunk with Dawn. Either way, there's no real warranty on these sheets. YMMV.
  • If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the onboard routine and much easier to make mid-print adjustments accurately with. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines on the PEI surface without dislodging them.  Then start lowering (more negative) the level until there are no gaps between layers. You should not be able to peel the lines apart after printing, but the top should be regular.
Remember that the effectiveness of a solvent such as isopropyl alcohol is going to depend on concentration and volume relative to the amount of grease you're trying to remove. 71% pads work... on very tiny amounts of grease. A squirt of 91% works better, but if there's a lot of grease, you need a lot more alcohol. This is why a wash under the sink with Dawn is so effective: There's a much larger volume of Dawn-and-water attaching to grease and rinsing stuff away instead of just moving the broken-down grease molecules around.
And above all else, avoid touching the PEI print surface.
Glue stick is NOT necessary for PLA on the PEI print surface. You paid the big bucks for a Prusa with a removable spring still sheet with PEI, so clean it up and take advantage of it. Save the glue stick for printing sticky stuff like PETG that might adhere too well. Even then, I only find I need glue stick when printing high-temp PETG at 260C+ temps.
Try those 2 steps. If you're uncertain of the Live-Z results, post pics here of the 75x75 print bottom and you'll get quick help. If you want more detail, I've consolidated my notes on Prusa PEI adhesion, bed cleaning, and Live-Z calibration
A bit of trivia - The reason higher concentrations of alcohol seem to be harder to find is that isopropyl alcohol is most effective against bacteria at roughly a 71% concentration. A bit of distilled water helps slow evaporation, making the alcohol more effective. If you're looking in pharmacies, that's why 91% and higher seem to be hard to find.
Veröffentlicht : 18/03/2021 2:24 pm
Tom R
(@tom-r-2)
@bobstro
Smooth PEI.
Thanks.
I will try both.
Tom
Tom Rauscher
Veröffentlicht : 19/03/2021 12:03 am
Tom R
(@tom-r-2)
Hello Everyone:
Thank you very much for your replies to my post.
I am happy to say because of your inputs, my Prusa in printing beautifully.
Thank you all so much.
Tom
Tom Rauscher
Veröffentlicht : 19/03/2021 12:58 pm
