Anyone Living in the San Diego area?
Hello:
Anyone living in the San Diego area who would be open to tune my new printer.
It became out of sink during the shipment.
Tom
Tom Rauscher
RE: Anyone Living in the San Diego area?
Hey Tom, great name! I'm in SD and just got my MK3S+ up and running (it arrived a few days ago). Still dialing it in, but it's printing well. What issues are you having?
@dorf
Hello:
The current issue is nothing will stick.
I am running the "First Layer Cal" in calibration and the print fails every time because it does not stick to the bed.
I try fining tuning it as it is printing but the print either moves around the bed or the filament bunches up under the needle.
Any suggestions.
Tom Rauscher
A dirty PEI print surface. Even if you don't think this is the cause, it's always a good idea to make sure your PEI surface is clean before trying any other fixes. If it's a smooth PEI sheet, take it to the kitchen sink and give it a good dunk with Dawn (original formula, no vinegar or hand softener variants) dishwashing soap or your local equivalent (e.g. Fairy in UK). Use a clean paper towel to clean it off, and another to dry it. Avoid using any sponge or cloth that has been in contact with grease. Above all else, avoid touching the PEI print surface. Once it's good and clean, you should be able to use 91%+ isopropyl alcohol between prints, 100% acetone when that fails , and another dunk when acetone fails. Worst-case, use a 3M 7445 ScotchBrite (1200-1500 grit) pad or equivalent on smooth PEI to give it a very light buff, but only infrequently. If you've got a textured powder-coated PEI print surface, the official instructions are to use 91%+ isopropyl alcohol on it only. Rumors persist that some have had good luck getting started with these sheets by giving them a wipe with 100% acetone and a dunk with Dawn. Either way, there's no real warranty on these sheets. YMMV.
If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the onboard routine and much easier to make mid-print adjustments accurately with. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines on the PEI surface without dislodging them. Then start lowering (more negative) the level until there are no gaps between layers. You should not be able to peel the lines apart after printing, but the top should be regular.
@bobstro
Smooth PEI.
Thanks.
I will try both.
Tom
Tom Rauscher
Hello Everyone:
Thank you very much for your replies to my post.
I am happy to say because of your inputs, my Prusa in printing beautifully.
Thank you all so much.
Tom
Tom Rauscher
