Alternative to changing Live Z when I change print sheets?
Neddy
(@neddy)
So, I've had my MK3S for a few weeks now, and I got both print sheets with my printer. I have worked out that I need to adjust the live z when I change sheets as they are different thicknesses. At the moment, I just have both values recorded, and when I change sheets I adjust the live z.
Is this the right approach?
Is there anywhere in the firmware to save the two alternative z height adjustments so that I can just choose the right one depending on which sheet I use?
Thanks
Best Answer by muddymaker:
It's available in the latest firmware release albeit not the final release but it's stable and works fine for me.
Firmware 3.8.0-RC2 for Original Prusa i3 MK3S & MK3
Steel sheet profiles
Magnetic heatbed on MK3S/MK2.5S enables using multiple steel sheets for continuous printing. However, due to a different thickness of various sheets (textured vs smooth PEI), each sheet requires individual First layer calibration. Starting with this release, we are adding a feature, which will store the settings for up to 3 sheets. You can then easily switch between the sheets (profiles) and the printer will load the stored values.
To set up the individual sheet profiles, please head to the Settings -> HW setup. There are currently three sheet profiles available.
-> For each sheet you can do the following:
  • Select - confirms the selection of the sheet, which will then become default
  • First layer calibration - takes you through the first layer calibration process
  • Rename - enables you to change the name, up to seven characters
  • Reset - sets the values back to the factory defaults
  • As soon as two or more profiles are configured, you will be able to quick-toggle between them in the main menu. A detailed description of the behaviour will be released with the final version of the firmware 3.8.0.
Download link:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.8.0-RC2
Opublikowany : 06/09/2019 1:38 am
muddymaker
(@muddymaker)
RE: Alternative to changing Live Z when I change print sheets?
Download link:
Opublikowany : 06/09/2019 7:46 am
2 ludzie polubili
Neddy
(@neddy)
Thank you! Exactly what I was hoping for!
Opublikowany : 06/09/2019 1:17 pm
Robin
(@robin-4)
Not sure if this is what your trying to do.  You can set a printer profile within slicer. I set a printer profile for each different print sheet i have and just add the Z height difference to the Offset either + or -
https://manual.slic3r.org/configuration-organization/configuration-organization
Opublikowany : 06/09/2019 9:26 pm
Sembazuru
(@sembazuru)
Posted by: Neddy
I don't know if you have noticed, but the final release of 3.8.0 is now available.
See my (limited) designs on:
Opublikowany : 07/09/2019 12:48 am
1 ludzie polubili
