align to a surface
bertrand.m2
(@bertrand-m2)
align to a surface
with Slic3r, is there a way to orient an object in order to align a specific surface on the build plane ?
currently I'm doing the rotation manually by entering a number, but it's not a very good way to do it.
Or are you using another software to orient the .STL resave it and then open it nicely in Slic3r ?
thanks for your help
Postato : 24/09/2018 12:28 pm
toaf
 toaf
(@toaf)
Re: align to a surface
bottom button on the left
Postato : 24/09/2018 1:12 pm
Kai
 Kai
(@kai-2)
Yep, and then you hit the part on the area that you want to align with the surface.
The scopes are highlighted .
nec aspera terrent
Postato : 24/09/2018 1:37 pm
always assuming you have the latest Slic3r
mine is 1.41.0+win64
linux and mac versions are available
Joan
Postato : 24/09/2018 2:16 pm
bertrand.m2
(@bertrand-m2)
I've never seen those button, but I'm on 1.40.1
I'll update my software to check if it's a new stuff that I've missed.
Ok, this is a new option of the version 1.41.
Cool it's doing what I needed.
Postato : 24/09/2018 2:35 pm
