align to a surface
with Slic3r, is there a way to orient an object in order to align a specific surface on the build plane ?
currently I'm doing the rotation manually by entering a number, but it's not a very good way to do it.
Or are you using another software to orient the .STL resave it and then open it nicely in Slic3r ?
thanks for your help
Re: align to a surface
bottom button on the left
Yep, and then you hit the part on the area that you want to align with the surface.
The scopes are highlighted .
nec aspera terrent
always assuming you have the latest Slic3r
mine is 1.41.0+win64
linux and mac versions are available
Joan
I've never seen those button, but I'm on 1.40.1
I'll update my software to check if it's a new stuff that I've missed.
Ok, this is a new option of the version 1.41.
Cool it's doing what I needed.
