Adjusting speed on the printer
Cynan
(@cynan)
Hi!
If you're using stock settings in PrusaSlicer, because, you know, you're new and don't want to mess anything up (!), what speed can you go up to on the printer itself via the control knob?
I've only dared try this last night (had the printer approx. 3 weeks) and I went up to 180%. Print seems alright. I was worried that I could damage the hot end if I tried to go to fast without adjusting the temperature? Would it be obvious if I did go to high? I'm sure I heard Jo Prusa say that you should be able to go up to 200% in a video without issues. Is that as far as I should go without changing temp. or any other settings?
Thanks!
Mark.
Opublikowany : 10/06/2020 8:47 am
RE: Adjusting speed on the printer
It will depend on the part and how often the printer hits its limits. Smaller parts are often printed at much lower than specified speeds due to physical limits on how fast the nozzle can be moved. Speed is an illusion. What you really want to focus on for faster prints is moving plastic, not nozzle linear speeds.
Opublikowany : 10/06/2020 12:30 pm
1 ludzie polubili
Cynan
(@cynan)
Great article - cheers.
Opublikowany : 10/06/2020 7:52 pm
