Add Geocode Automatically from inside the Prusa Slicer?
akerezy
(@akerezy)
Is there a way to store extra Geocode that would get added in the process of creating the Geocode with the Prusa Slicer?  For example - I want to add Geocode that makes the printer beep, and then moves the extruder up further away from the build plate.
I do not want to MANUALLY add this.... I wanted to store this in a template used by the Prusa Slicer, and just "apply" it, or have the software add it whenever creating new Geocode for a part.
Can it be done????
Opublikowany : 22/04/2020 11:08 pm
Area51
(@area51)
RE: Add Geocode Automatically from inside the Prusa Slicer?
G-code can be added in Printer Settings -> Custom G-code when in Expert mode.
For more advanced mode, a postscript can be run after G-code generation: Print Settings -> Output options -> Post processing script (Advanced or Export mode).
Opublikowany : 22/04/2020 11:19 pm
