Abused Prusament
JMcK
 JMcK
(@jmck)
Abused Prusament
In general, I'd say my handling of filament spools is "OK" I'm not the most OCD person out there, but I'm no Schlub either. (this story notwithstanding)  I keep open spools in a sealable container with rechargeable desiccant. If I think it will be a while before I'll use a given spool again, I'll vacuum seal it with my food saver.
Today I pulled out a spool of Galaxy Black, that I hadn't used in a while and discovered that I had actually NOT vacuum sealed it. So it's been sitting naked in my dry(ish) box box all this time. Spool says it was manufactured December 2018! so it's been open probably a bit less than 2 years, but that' still pretty long, and it's still pretty full. "It's probably fine," I told myself. I was wrong. It's SO brittle, that it snapped off just trying to stick it in the extruder.
A while back I designed and printed an adapter to let me use my NESCO food dehydrator as a spool dehydrator. I didn't want to post the adapter design until I tested it, but I never got around to the testing. I think this is a pretty good torture test.  It's currently sitting at 115ºF/45ºC. Anyone have any thoughts on if I should change the setting, or how long should I have it go? Anyone think trying to recover a spool that far gone is a bad idea?
When someone asks you if you're a god, you say, "YES!"
Posted : 07/02/2021 9:43 pm
jsw
 jsw
(@jsw)
RE: Abused Prusament
What was the approximate relative humidity where it was kept?
Some say that PLA can be left for some time without concern in most domestic environments.
If I were you, I would just do a simple test print to see how it works.
In any case, some time in the warm dehydrator should drive out any moisture.
Posted : 07/02/2021 9:54 pm
I keep any filaments that may sit out for more than a week in a Camera Cabinet to prevent humidity.  You can also use silica beads and zip baggies.
Posted : 08/02/2021 4:08 am
JMcK
 JMcK
(@jmck)
Posted by: @jsw
Relative humidity: My windows fog and drip, and my ceilings look like 101 Dalmatians.
Posted : 09/02/2021 2:36 am
Posted by: @jmck
Posted by: @jsw
Really?  I would have a talk with your landlord or is that a slumlord.
Posted : 09/02/2021 3:11 am
JMcK
 JMcK
(@jmck)
Just circling back for future readers. An overnight stay in my food dehydrator and the filament was good as new, and printed beautifully.
Posted : 17/04/2021 6:00 pm
@jmck
Good news.  I have had a few rolls need this to print.
Posted : 17/04/2021 7:03 pm
Swiss_Cheese
(@swiss_cheese)
Posted by: @jmck
That's good because Galaxy Black comes in PETG, ASA, and PLA and at no time did you mention what type of filament this was, and it matters.
good Luck
Swiss_Cheese
The Filament Whisperer
Posted : 18/04/2021 5:52 am
JMcK
 JMcK
(@jmck)
@swiss_cheese
Fair point. PLA.
Just trying to be helpful here. Abject apologies for missing the mark.
Posted : 20/04/2021 12:39 am
StanHD
(@stanhd)
Posted by: @jmck
Good to know, thank you for the info.
Posted : 20/04/2021 8:17 am
