3.10.0 Firmware for MK3, MK3S, MK3S+
Page 2 / 3
Niels S
(@niels-s)
RE: 3.10.0 Firmware for MK3, MK3S, MK3S+
How do I load the new dutch translation file into this firmware. Dutch (or Netherlands) doesn't show up under -> LCD menu -> Settings -> Select language -> Community made. If I go there, there are no file to choose from...
I had this same ' problem'  in the last RC of this 3.10. Could somebody explain what I'am doing wrong?
This post was modified 5 years ago by Niels S
Posted : 12/05/2021 2:21 pm
Sebbl2
(@sebbl2)
@der_da
Unfortunately I do not understand much of what the devs are talking about, but I have these annoying clicking sounds as well. And I did not even check the silent mode. I also had my first clogged heatbreak since months. I don’t know if this is related to this issue, hopefully there will be a solution for that.
MK3s, Ender 5
Posted : 12/05/2021 7:10 pm
der_da
(@der_da)
@sebbl2
Did you actually activate the E cool mode in the experimental menu? With it deactivated (default) my extruder doesn't produce any unusual noise.
Posted : 13/05/2021 1:38 pm
der_da
(@der_da)
@niels-s
How did you flash the firmware? It's been said, that only flashing through PS currently also puts the language files into place. Flashing via Octoprint or such would not do that.
Posted : 13/05/2021 1:39 pm
I've had my very first print fan error since purchase. The fan was spinning when it beeped the error. So no clue what that is about. But I'm thinking the interrupt flag bug from v x.x that kept the Mk3 laser filament sensor from working well is still there. lol.
This post was modified 5 years ago by --
Posted : 13/05/2021 7:36 pm
Hiro Protagonist
(@hiro-protagonist)
Anybody tested the time till M600 yet? My burning question is whether it was implemented for M600 and M601. I use M601 every day.
Posted : 17/05/2021 1:22 am
@tim-2
Not yet.  I will keep an eye out and post back.
Posted : 17/05/2021 2:09 am
Niels S
(@niels-s)
@der_da
I do upload firmware with octoprint.... Why doesn't that work? Isn't that strange? I'll try renew my firmware using the usb cable with prusaslicer. I'll keep you guys posted
Posted : 19/05/2021 12:25 pm
Niels S
(@niels-s)
@der_da
with the usb cable pluged in it did work when trying for the second time
It's now in dutch. Great work 😉
Posted : 19/05/2021 12:52 pm
kenryan
(@kenryan)
Posted by: @tim-2
What is the "official" EEPROM write spec?  How many times can you write the job variable block/bytes before you can expect the chip to fail?
Per the datasheet the EEPROM is rated for 100,000 write cycles.  Being EEPROM that is on a per-byte basis.
Edit: The first failure mode for wearing out is data retention time, so even if you manage to do 100,000 prints without wearing out the motors it will effectively last much longer than that. 🙂
Posted : 21/05/2021 2:02 pm
Kaptajnen
(@kaptajnen)
Trying to update, but get stuck here with "Flashing failes. Please see the avrdude log below"
PC responding on cable/MK3 perfect. Have tried to update several times. No problem ever. But not on this 3.10.0 vers.
Running on vers. 3.9.3-3556 now.
Any suggestions?
Best regards
Posted : 23/05/2021 11:15 pm
Kaptajnen
(@kaptajnen)
Posted by: @kaptajnen
Any suggestions?
Best regards
.... and i have tryed with the correct update file allso 😉 MK3 (not S)
Posted : 23/05/2021 11:23 pm
@kaptajnen
What's the AVR log show?
Posted : 23/05/2021 11:35 pm
Hiro Protagonist
(@hiro-protagonist)
Posted by: @hiro-protagonist
I upgrade my Mk3S, but not Mk2.5S. The print I do which has M601 for magnet insertion doesn't seem to generate any new messages. So I think it wasn't implemented for M601.
Posted : 23/05/2021 11:37 pm
I had it failed on one printer.  I kept hit install - about 6-8 times till it completed the upgrade.
Posted : 24/05/2021 12:58 am
Kaptajnen
(@kaptajnen)
@tim-2
I am not sure what you meane? Just tried to delete alle my drivers, remove my Bluetooth dongle (that was on the same port (3)).
Tried to re-install everything. Factory reset printer. Run throug the wizard again. Still no firmware upgrade for me 🙁
Posted : 24/05/2021 10:59 am
romeoalfa1975
(@romeoalfa1975)
Danke für das regelmäßige Verbessern der Firmware! Wird in der kommenden Version auch die Reaktion des Drehknopfes deutlich verbessert? Die Bedienung ist sehr schwierig, wenn das Menü nicht bei jedem Drehen des Knopfes reagiert oder sogar in die falsche Richtung springt.
Posted : 01/06/2021 8:47 am
Sebbl2
(@sebbl2)
@der_da
You were right, normal mode everything seems ok, at least for the e-steps. I am looking forward for the next update.
MK3s, Ender 5
Posted : 01/06/2021 8:54 am
Texy
 Texy
(@texy)
So.....when will a new version of PrusaSlicer be revealed, so that we can utilize all the new features of the mk3/s/+ firmware ?
Texy
Posted : 07/06/2021 10:41 am
Michael Stuecker
(@michael-stuecker)
I installed 3.10.0 and I am not able to choose the language german. After selecting the language I always get back in the language selection menu... unless I choose english...
Posted : 23/06/2021 5:10 pm
Page 2 / 3
