2nd Printer, MK3S and MK3, slice for both?
buckeyestargazer
(@buckeyestargazer)
Yesterday I assembled my second printer (MK3s) (first time assembling one!) and I also have an MK3.  I have several models sliced for the MK3 that I wanted to copy over to the MK3s so I could print any of my models from both printers.  When I try to print one of the MK3 models on the MK3s there is a message on the display saying something like "this gcode was meant for a different printer profile do you want to continue".
Is there a way to disable that message or do I need to re-slice the models with the MK3s printer profile?
Best Answer by karl-herbert:
@buckeyestargazer
Another possibility would be to change the hw-settings -> controll in the printer (LCD) settings:
Nozzle: warn
Model: none <-
Firmware: none <-
Publié : 20/11/2020 10:41 pm
RE: 2nd Printer, MK3S and MK3, slice for both?
Posted by: @buckeyestargazer
This is only a status message. The gcode should normally be printable on MK3S without problems. The only difference is the filament sensor, which should not affect any function.
Publié : 20/11/2020 10:54 pm
buckeyestargazer
(@buckeyestargazer)
Posted by: @karl-herbert
Right, but I don't want to have to push the button to start the print (I'm using Octoprint).  Or does it just continue without pushing the button?  I assumed that message had to be cleared so I always just pushed the button before any printing started.
Publié : 20/11/2020 11:07 pm
@buckeyestargazer
Try to disable or comment out M16 (printer name).
Publié : 20/11/2020 11:40 pm
or, if available, comment out this line in start gcode in the slicer:
M862.3 P "[printer_model]" ; printer model check
Publié : 21/11/2020 1:14 pm
buckeyestargazer
(@buckeyestargazer)
Thanks.  I know I can comment out the gcode in future slices.  But for the current gcode files I already have I was hoping I could somehow suppress that message without having to alter anything.  Not a big deal at all.  Thanks again.
Publié : 21/11/2020 1:19 pm
@buckeyestargazer
Nozzle: warn
Model: none <-
Firmware: none <-
Publié : 21/11/2020 3:16 pm
This article describes the menu system BEFORE firmware 3.9.0 for the Original Prusa i3 MK3S:
https://help.prusa3d.com/en/article/lcd-menu-i3-pre-firmware-3-9-0_1876
Publié : 21/11/2020 3:18 pm
buckeyestargazer
(@buckeyestargazer)
@buckeyestargazer
Nozzle: warn
Model: none <-
Firmware: none <-
This is what I was looking for.  Thanks!
Publié : 21/11/2020 3:20 pm
