Z Offset - hardware calibrated vs slicer - simplify3D
mgtarallo
(@mgtarallo)
Hi guys - I am new to Prusa, but not 3D printing. I have been using a Lulzbot Min and Cura Lulzbot edition for about 1 year now. (Recently, I was having hardware problems with my Lulzbot - and found out that Aleph Objects laid off all their staff and sold all its assets to FARGO and is no longer supporting its customers at the moment - which is shame.) - I wanted to get another printer that had great reviews and found Prusa. I am very excited however to now own a Prusa, but I know I need to relearn a little bit.
I purchased an already assembled i3 - after turning it on and watching it go through its steps - I realized I did not cut the cable ties underneath the bed. After doing so - I feared I might have screwed something up - so ran a full reset calibration. I performed a LIVE Z offset and was able to get the filament to look like the one in the handbook and it adhered well. I printed the whistle from the SD card and it looked great - though there was a bunch of loose filament inside the whistle - I assumed that was normal - but is it?
NOW - I wanted to try one of my .STL files via USB using Simplify3D and a i3 profile I got from a friend. I tried to print a small joystick button - and it appeared that the Z axis was too high. The filament did not look squished and the button crumbled.
My question - can a Prusa profile used in  simplify3d or other slicing tools override the tool head Z axis settings / offset? I assumed that since I adjusted the setting on the hardware it would respect that height. I assume I am missing something.
What I have seen so far is  that this is an amazing printer - I wish I would have just got one of these first instead of dealing with the lulzbot headaches.
Thanks for your time.
Veröffentlicht : 19/11/2019 1:38 pm
RE: Z Offset - hardware calibrated vs slicer - simplify3D
Generally, Z-offset in the slicer is set to zero.  This allows the firmware based Live-Z setting to work properly.
ps: you might want to try Prusa Slicer and the included default profiles to become familiar with the MK3.  It might avoid some confusion in whether or not a slice or the printer is the issue.  Once you get through a few prints, then start reading the forums for setting up your Simplify3d profiles.
Diese r Beitrag wurde geändert Vor 6 years von --
Veröffentlicht : 19/11/2019 9:51 pm
towlerg
(@towlerg)
Don't know if it helps but you can get Prusa settings for Simplify3d from the download page https://www.prusa3d.com/drivers/
Diese r Beitrag wurde geändert Vor 6 years von towlerg
Veröffentlicht : 20/11/2019 2:02 pm
mgtarallo
(@mgtarallo)
@towlerg
Thank you - I just did that today - I will test !
Veröffentlicht : 20/11/2019 4:42 pm
