Z calibration width Ok (1.1 mm) but square test is KO
Hello, I watch this video on the calibration of Z-axis and the recommended width is 1.1 mm so i set the high to obtain this width,but the little square at the end doesn't look good. Any idea what I missed ?
Bellow a picture of the square ( from what I understand it means i am too low )
Regards
Vincent Diallo-Nort
Best Answer by cwbullet:
That might be a bit too low. I usually raise my live Z or Z offset by 0.025 and try printing again. You can adjust up or down from there till the square is perfect. Remember minus is down and Positive is up.
Offset
Thanks
Thanks
