Z-axis (left spiraled rod) is Wobbling
I recently upgraded a company machine from MK3 to MK3S. Due to COVID-19, I took the machine home with me, which required a 5 hour drive. I think this may have knocked some things out of alignment.
The self test passes, but when I do the XYZ calibration I get "Calibration failed! Check the axes and run again" when the extruder reaches the plate. The PINDA probe LED is red. I have already tried a factory reset.
I noticed while the test was running that the left rod used for the Z axis is wobbling a bit, left to right and back. Is there something I can try? Is this rod bendable?
Opublikowany : 03/07/2020 7:36 pm
