[Solved] Z axis calibration
Marek Jaros
(@marek-jaros)
Z axis calibration
I have to remove blob from extruder and something must be shifted, because actualy the printing is wrong.
When I tried calibrate Z axis, the test stoped on spot 7 of 9 - on the top-left corner. On this spot my extruder attemps dive under bed and push it down. And the test has been stoped.
Thanks for any advice
Marek
Best Answer by JoanTabb:
when that happens,
is the Pinda, off the side of the heatbed? (if it's over the side, it won't see the heatbed... look for faulty bearings or lack of lubrication causing the print head to jam...
If the Pinda is still over the heatbed look for a broken wire on the pinda
regards joan
Napsal : 27/02/2024 8:44 pm
RE: Z axis calibration
when that happens,
regards joan
Napsal : 27/02/2024 9:42 pm
1 lidem se líbí
Marek Jaros
(@marek-jaros)
Thnaks, but why it faults on seventh spot? The first, second and nexts are going well.
Napsal : 27/02/2024 10:09 pm
 No idea, not seeing the printer makes everything a guess...
Joan
Napsal : 27/02/2024 11:10 pm
Marek Jaros
(@marek-jaros)
TYVM,
I fix by replacing PINDA
Marek
Napsal : 06/03/2024 6:36 pm
