Y-Carriage Crunchy Linear Bearings? As if Metal on Metal
Brian Flores
(@brian-flores)
(POSSIBLE ISSUE)
- I received and started assembling my new Prusa I3 MK3 kit.
- On first build 2. Y-axis assembly. http://manual.prusa3d.com/Guide/2.+Y-axis+assembly/507?lang=en
- On Step 22 Y-axis: Y-carriage
- The LM8UU linear bearings make a crunchy metal on metal sound and feel, when I move the Y-axis carriage back and forth down the rods. Similar to nails on a chalk board cringe moment.. as if something is not right.
- Saw others with similar concerns. They contacted Prusa Support and they sent new bearings and rods.
- Some have purchased alternate brands and types of bearings and rods (Mitsumi, VXB, igus drylin)
(QUESTION)
- Is the crunchy metal on metal sound and feel with the linear bearings and rods normal? Should I just move on with the build and it will work itself out?
(WHAT I HAVE DONE SO FAR)
- Submitted the above to Prusa Support via prusa3d.com contact us page.
- I ordered new bearings from vxb.com to see if there is a quality difference. http://www.vxb.com/3D-Printers-Linear-Bushing-set-12-LM8UU-6-p/kit180023.htm (
Posted : 13/04/2018 4:56 pm
RH_Dreambox
(@rh_dreambox)
Re: Y-Carriage Crunchy Linear Bearings? As if Metal on Metal
Yes, fast moves cause a crisp sound, but it's normal.
If you want a lower noise level then you need to replace the ball bearings with sliding bearings.
The noise is nothing that botheres me because the printer is so quiet that I could have it in the bedroom 😀
Posted : 15/04/2018 5:32 pm
Brian Flores
(@brian-flores)
Here is what it sounds like with the factory linear bearings.
Posted : 15/04/2018 6:09 pm
Gato
 Gato
(@gato)
Have you tried:
1) Adding general purpose machine oil on the smooth rods?
AND
2) Adding lithium grease inside of bearings?
See:
https://help.prusa3d.com/l/en/article/sVQHD6vtfm-bearings-maintenance
Posted : 16/04/2018 12:17 am
Brian Flores
(@brian-flores)
Have you tried:
AND
See:
Thank you. Excellent link.
I have not tried anything but new Prusa stock. I will try lube, if the thrid party bearings, from VXB, produce the same results. They arrive in 2 days. I'll post a video and result.
Posted : 16/04/2018 12:45 am
Kai
 Kai
(@kai-2)
You should also test it without the Belt atached to the Bed/Motor.
1.Because the stepper motor generates noise itself.
2. Fast movements could kill parts of the electronics.
3. you won´t "feel" slightly to tight bearings with the motor attached.
nec aspera terrent
Posted : 16/04/2018 11:04 am
Kai
 Kai
(@kai-2)
Btw. the (sliding) Igus bearings have a lot of side clearance on the y axis.
nec aspera terrent
Posted : 16/04/2018 11:06 am
Brian Flores
(@brian-flores)
Thanks for the input guys. I received the VXB linear bearings today.
It makes the same noise. I will assume this noise is by design, and normal. I will proceed with the build using the Prusa factory bearings.
I may also try those plastic Igus models, if it makes load noises when printing.
I just saw videos where the vloggers are saying how quite the MK3 is. Maybe its not so load when printing. I dunno.. My first. I will come back to this post later if its load.
Thanks again everyone!
Posted : 18/04/2018 5:17 pm
Brian Flores
(@brian-flores)
WOW! So sorry for making this thread. No noise issues at all when printing.
(MY NOOB RESULTS)
- Prusa MK3 Linear Bearings are loud when moving back and forth by hand.
- VXB Linear Bearings made no noise difference. Same level of noise.
- When printing, you do not hear the same noise, when moving by hand.
- The Prusa I3 MK3 stock Linear Bearings are wicked quite when printing!!
(VIDEO OF PRUSA LINEAR BEARINGS PRINTING)
PS. I need help, or more practice on making prints stick to the bead, as you can see in the video. I will try another .050 lower on the Z.
Posted : 20/04/2018 7:25 pm
denis.l5
(@denis-l5)
Hi Bryan,
Exactly same here. Among the three bearings, one is perfectly smooth, and can be thrown from one rod's end to the other, the two others seem to have square balls, and can't even been turned around the rod axis. As per your experience, I'll finished to mount the printer and see if at the end the result is correct or not, but as an engineer, this is everything but mechanically satisfaying... Thanks for your thread, at least it shows that I'lm not alone 🙂
Denis
Posted : 12/05/2018 2:23 pm
digibluh
(@digibluh)
it technically is metal on metal...
Posted : 13/05/2018 6:59 am
Brian Flores
(@brian-flores)
(5 MONTH PRO UPDATE)
- Still printing quite.
- Stock Prusa bearings are still doing just fine.
- Oh.. and I no longer have that print warping issue, since I started using glue sticks.
(5 MONTH CON UPDATE)
- 5V Print Fan broke. Fan no spin. Cable fine. Actual Fan Defective. (warranty covered and replaced, arrived 3 days via DHL to US).
- Heatbed Thermistor cable broke. Cable had a break in the line. Actual Thermistor OK. (warranty covered and replaced, arrived 3 days via DHL to US).
Posted : 11/09/2018 3:39 am
jacob.p10
(@jacob-p10)
I'm really happy you did 🙂
I just built my Y-axis yesterday, and I spent the night and most of the day worrying about that exact sound, so I was really happy to find this thread.
Posted : 31/01/2019 7:57 pm
Chocki
(@chocki)
Mine was like this as well when I got it, so I basically flooded the bearings with singer sewing machine oil, let them stand to drain excess, then assembled. Runs nice and smooth now, but still makes some noise but nothing like it did new (dry).
I bought one of those needle tip precision oil dispensers and put a couple of drops on the rods every once in a while, and clean the dust the bearing seals push along the rods off with a paper towel when I can see any buildup.
Seems to be running well with this, just don't go too mad on the X axis as oil could drip onto the belt.
Also, ditch those U bolts.
I found these: https://www.thingiverse.com/thing:2830466 fit perfectly with no nuts needed, just use m3 cap heads long enough to just poke out the holes and screw them in until the clamp is against the X frame and that's it, not to tight and not to loose.
Posted : 31/01/2019 9:08 pm
