Y belt alignment issue
morf
 morf
(@morf)
Hi Folks
I have an assembly problem. I got stuck at alignment of y belt.
I followed the instructions carefully but no matter how hard I try the belt is always moved to the left side of the pulley.
It's not bending but I think it might impact it's lifespan. The problem is I cannot move pulley further towards motor because then it blocks the movements of the shaft.
I guess I can possibly reverse the pulley but it would be non standard way ...
Any tips? Thanks
This topic was modified před 6 years 2 times by morf
Napsal : 10/02/2020 4:45 pm
rmm200
(@rmm200)
RE: Y belt alignment issue
You are not the only one to question this. Read the comments on Step 32:
https://manual.prusa3d.com/Guide/2.+Y-axis+assembly/1046?lang=en
Note the response to carefully check the installation of the idler pulley.
Napsal : 10/02/2020 4:59 pm
Galinette
(@galinette)
Did you solve this? I have exactly the same issue. I triple checked, everything is in the right position. But belt is on the left of both pulleys.
Napsal : 20/12/2021 8:32 pm
morf
 morf
(@morf)
Actually I reversed the pulley already when assembling the printer.
I've been printing happily days and nights 😃
Napsal : 20/12/2021 8:41 pm
Galinette
(@galinette)
Thanks for your reply.
I noticed this while assembling, but kept following the exact instructions.
Now I'm experiencing Y crash detection when the axis is close to ends, and triple checked everything. I may give it a try. This could explain a slight extra resistance at the ends.
Napsal : 20/12/2021 8:45 pm
Emcull03
(@emcull03)
I just flipped the direction of the pulley and it fixed all my issues!
Napsal : 21/12/2021 1:03 am
