[Solved] Y-Axis Mysterious Crashes
DFliyerz
(@dfliyerz)
I've had my MK3S for a couple weeks now and have greatly enjoyed it, but one thing that's been causing issues since the initial assembly is that if crash detection is on, the printer will detect y-axis crashes for seemingly no reason at around 10-13mm. It prints fine with crash detection off, but as soon as I turn it back on the crashes happen pretty consistently. I've checked all the belts, adjusted the tightness of the u-bolts on the bearings, and re-lubricated all the linear rods but the crashes still happen. Any help?
Posted : 11/05/2020 5:53 pm
JustMe3D
(@justme3d)
RE: Y-Axis Mysterious Crashes
Is this happening always with the same model?
Posted : 11/05/2020 6:13 pm
DFliyerz
(@dfliyerz)
@just3d
I usually test it and have it happen on the benchy that's included on the SD card, but I've also had it happen on other models too. I can try and slice a benchy in Cura (which is my main slicer) and see if it happens there too.
Posted : 11/05/2020 7:44 pm
DFliyerz
(@dfliyerz)
It seems to be fixed? I've run a benchy sliced in Cura with z-hop and one without z-hop and it seems like it's not happening anymore. However I'm going to leave this as unsolved for a couple of days to see if it comes back.
Posted : 12/05/2020 5:36 am
Thanks for the Update,
Best wishes for further success,
Happy  Printing
Joan
Posted : 12/05/2020 12:10 pm
DFliyerz
(@dfliyerz)
Marking this as fixed, as it's been about a week and I haven't run into any more issues. I'm planning to do a full degreasing and re-lubrication of the bearings with lithium grease once some isopropyl alcohol arrives.
Posted : 17/05/2020 7:11 pm
