[Rozwiązany] Y axis length
hiflyer152
(@hiflyer152)
Y axis length
Just received assembled MK3s, ran self check & got message to clear nozzle.  Heated nozzle & removed filament (in when printer arrived).  Re-run selftest and now get message: Selftest error: Please check axis length, axis y
I didn't assemble and didn't receive instructions on how to set printer up so I really don't want to begin "adjusting" or modifying what was previously done without clear, specific instructions.
Thanks in advance, Michael
Opublikowany : 12/06/2020 7:30 pm
RE: Y axis length
Posted by: @hiflyer152
Hello and welcome in Prusaforum!
congratulations to your Prusaprinter. This is bad luck that your printer causes problems right from the start.
The Y-axis may have a problem with the linear bearings, the belt or something is blocking the axis.
The easiest way is to contact Prusa over chat. Login with your account, select the eshop. After a few seconds a chat window appears. This is the fasted way to get help from Prusa.
good luck!
Opublikowany : 12/06/2020 11:38 pm
