Y axis length failure
Daniel Weitz
(@daniel-weitz-2)
what would cause a 'Y axis length failure' on the selftest.  There is also a strong clicking sound.  What is the solution?
Respondido : 28/09/2019 5:23 pm
RE: Y axis length failure
The bed must move 210 mm; easy to measure.  Manually slide the bed to the front then to the back, it should move 210 mm, or a bit more.  Anything that prevents that range of motion will cause a failure.
Bearings installed wrong; cable ties positioned wrong (the build instructions are very clear); cables routed where they interfere; U-bolys installed where they interfere (very close tolerances, any positioning errors they can hit the frame); etc.
Another common cause if the motor drive gear is not installed correctly, or a loose belt.
Esta publicación ha sido modificada el hace 7 years por --
Respondido : 28/09/2019 6:00 pm
Daniel Weitz
(@daniel-weitz-2)
I retightened the screws on the belt mounts after moving one a bit more to the far side to stretch the belt.  Now its working!
many thanks.
Respondido : 28/09/2019 6:44 pm
