Y Axis length error (motor doesn't know when it's hit limits)
Alex Donaghue
(@alex-donaghue)
During the self check the Y Axis fails. I have posted a link below of what it does before it fails the test.
Opublikowany : 08/06/2018 12:33 am
Olef
 Olef
(@olef)
Re: Y Axis length error (motor doesn't know when it's hit limits)
Your Y motor pulley is loose on the motor shaft, or your belt is too loose and is skipping on the pulley. I can see it still rotating when the bed has reached its limit. Tighten the grubscrews properly / tension the belt.
Opublikowany : 08/06/2018 1:00 am
