Y-Axis Layer Shifting
Hello
Recently I've had some trouble with my Y-axis. Many prints had some sort of layer shifting happening.
First Layer is always off by a bit, but saw that on other printers too. Then it usually goes well for some time until it shifts again.
Today however I had a horrendous print (see pictures). X-axis is perfectly fine.
Belt tension seems fine to me and is within the range of prusas measurement (x-250, y-270).
Did lubricate the y-axis after the print today, will see if that helps in any way.
Thanks in advance.
Respondido : 03/11/2025 6:32 pm
RE: Y-Axis Layer Shifting
Did lubricating it help?
It seems like you're following this guide but just in case: https://help.prusa3d.com/article/thermal-model-calibration_382488
Respondido : 06/11/2025 1:54 pm
