XYZ Callibration issue - z axis problem
paul.t19
(@paul-t19)
Just attempted my first calibration on a newly assembled printer.
X/Y axis all good. My problem appears to be the z axis. During the calibration it should raise the print head to the top of the z axis. On my printer it raises about 2 inches then stops without an error message asking me to insert a piece of paper for the next step. If I repeat this step it will move up a further inch or two but still not reach the top. Eventually (with several repetitions) it reaches a point about 2 inches from the top of the z axis and will go no further.
I can manually raise the print head by turning the trapezoid threads with my fingers and there doesn't feel like there are any tight spots.
If I continue the calibration procedure I get an error as the head touches the plate too soon.
Any suggestions?
Posted : 15/06/2018 5:41 am
Gato
 Gato
(@gato)
Re: XYZ Callibration issue - z axis problem
No idea what could cause this. While you wait for an answer here, you might want to contact Prusa Chat Support.
Posted : 15/06/2018 5:45 am
paul.t19
(@paul-t19)
Problem sorted thanks to Chat. (thanks William)
I needed to rotate one of the trapezoidal nuts 45 degrees relative to the other. It was a slight alignment issue.
Thankfully a simple but relatively obscure problem. I never would have got there on my own.
Posted : 15/06/2018 11:17 am
