XYZ calibration print head too low; First layer calibration print head too high
topdotter
(@topdotter)
When I run the XYZ calibration, the paper gets pulled (very slightly) at point 2. So I moved the Super PINDA probe down and the paper is still moving a tiny bit but much less. But now, when I do the first layer calibration, it's definitely not sticking to the bed and the final rectangle is printing exactly like the picture that says "Too high". What should I do?
Respondido : 21/11/2021 4:12 pm
Zoltan
(@zoltan-d-2)
Miembro Moderator
RE: XYZ calibration print head too low; First layer calibration print head too high
What is you live-z set after you finish the first layer calibration?
Respondido : 21/11/2021 6:57 pm
topdotter
(@topdotter)
0.00
Respondido : 21/11/2021 8:46 pm
topdotter
(@topdotter)
I didn't adjust z because I didn't want to scratch the surface. What should I do?
Respondido : 22/11/2021 3:40 pm
Dan Rogers
(@dan-rogers)
I would recommend reading the instructions and following them in order and do all of them.  The paper step is the first of three gradual calibration steps.  You can't do only step 1 and stop.
Respondido : 23/11/2021 11:19 am
