xyz calibration (not automatic)
I tried printing a 10x10x10mm cube https://www.thingiverse.com/thing:4579476 and measured some slight differences.
9.88x10.00x10.11
This is the calibration done by the wizard. I'm wondering if there is a way to adjust the firmware tuning, to get it dialed in even closer.
Postato : 25/08/2020 3:21 pm
RE: xyz calibration (not automatic)
I would print a larger calibration cube, let things like extrusion width and volume become less significant. 20mm or even 40mm for a good dimensional accuracy test.
Some time ago I printed three 20mm cal cubes as a sanity check, with PLA, ABS and PETg, all at .10mm layer size. All three came well within 1% when measured with a digital caliper and any of the I3 series should be able to do this.
Postato : 25/08/2020 4:46 pm
1 persone hanno apprezzato
