XYZ Calibration Failed. Please consult the manual.
cameronmcpherson11
(@cameronmcpherson11)
I have recently assembled my new MK3 and have not been able to get past the XYZ calibration. It goes through all 4 points and fails after the 4th point. Watching the PINDA, it appears to be within each circle for the 4 calibration points. I can not figure out what is wrong.
I have updated the firmware to 3.9.
I have checked the PINDA height to be the thickness of a ziptie as instructed.
I have done a belt test and am within the 240-280 window for both x and y.
I have tried resetting the XYZ calibration.
Nothing has fixed this issue. Someone please help!
Opublikowany : 10/07/2020 1:15 am
jsw
 jsw
(@jsw)
RE: XYZ Calibration Failed. Please consult the manual.
If this is a new out of the box printer, I would contact support.
Opublikowany : 10/07/2020 1:33 am
rluby
(@rluby)
Look at the support video about common assembly errors.
If you are having Y axis problems,  check that the Y axis u-bolts are not bent or misaligned.  Swap the u-bolt for a spare and see if that helps.
Opublikowany : 24/07/2020 5:49 pm
Peter M
(@peter-m)
Adjust pinda probe a little lower , and then do calibration again.(try 1 or 2 steps down).
Check all axis if wen the 3d printer is powered down, if all axis are moving without getting stuck.
Also check x axis, if cables at the extruder are not hitting to the left and wright(x axis).
Opublikowany : 24/07/2020 7:48 pm
