xyz calibration failed, check owners manual
My i3 passes the z calibrations but keeps failing the xyz calibration when it goes over the screw located right center that holds the bed down. It's the fourth location it checks during the calibration. After a reset the PINDA does not recognize the screw and the location in general as metal. I've I've moved the PINDA as low as possible, and tested w metal. it seems to be working.
Opublikowany : 21/10/2020 12:25 am
