xyz calibration failed-bed calibration point not found
Hi I recently finished building my Prusa 13 mk3s and am having trouble with the xyz calibration. I have aligned the PINDA probe but am still having problems. Does anyone have any other solutions that I could try?
Napsal : 20/04/2020 6:54 pm
RE: xyz calibration failed-bed calibration point not found
Move pinda probe a little higher and lower in small steps, start by set the pinda probe like in the manual.
Check all axis if these move without getting stuck, put also thin oil with PTFE inside the oil.
Check all axis wen they go to the outside/end of the printer, if they hit cables, look at extruder backside.
Napsal : 21/04/2020 3:01 pm
Topic starter
answered:
Thank you for your help Peter!
The problem was in tension of y-axis motor belt.
PS. It would be nice for Prusa to include in the printer assembly booklet a general guideline on how tight belts have to be.
Napsal : 21/04/2020 11:24 pm
