XYZ Axis Calibration Error
Hello,
I just built my MK3 and during the XYZ Axis Calibration it fails on the 3rd point. I'm not sure if lowering the probe will help at all but if I do, it will be closer than the prescribed "1 zip tie" height.
Napsal : 20/01/2019 12:14 pm
Re: XYZ Axis Calibration Error
I think you should check that the X and Y axes run smoothly between its end positions.
You should feel a certain resistance from the motors but it should be the same resistance all the way0
Also, make sure that no cable ties collide with the frame and that end pulley rotates freely.
Napsal : 20/01/2019 2:01 pm
