XY Calibration Problem
jt.t
 jt.t
(@jt-t)
I just received and built my printer this week. I had to make a few tweaks to get through the self test, but managed after a bit (hooray!). When moving to the XYZ calibration I'm hitting a problem where it cannot find the points for calibration. The PINDA sensor seems to be a good deal right of here it should be when searching. The issue is repeated when trying auto home. I've added a couple pics of the relative heights and the position it thinks is home. I have checked most of the parts I can think of and some of the suggestions online to no avail.
Any ideas of things to check?
Thanks!
Veröffentlicht : 11/04/2019 5:07 am
Re: XY Calibration Problem
PINDA is too low, and you've not assembled the hotend correctly: It needs to be rotated 90 degrees...
Veröffentlicht : 11/04/2019 5:58 am
