x-lenght calibration
Schalendorf
(@schalendorf)
Yea I know another x-axis calibration problem. So I already checked the wires, loosened the screws on the back... On the calibration it bums into the left side like its supposed too but about 1-2cm before hitting the right side it reverses course. I have checked that side but it is not hitting anything.
On other note can we for the love of 3d printing get an option to do the x-y length calibration separately to see if it work because it takes forever for the printer to cool down after a fail then having to run through the entire thing again....
Publié : 30/11/2018 8:10 pm
3dprinterrrrr
(@3dprinterrrrr)
Re: x-lenght calibration
Definitely would like to see this. Please consider this asap!
Publié : 14/12/2018 8:31 pm
3dprinterrrrr
(@3dprinterrrrr)
TL;DR: Use a paper under the PINDA height adjust process when moving the extruder (Step 9, Preflight). Rotate the threaded rods down until it contacts the paper and prevents it from sliding. Then raise it just a little bit so it slides without much/any resistance. Repeat for the right side. Move to the center and use a paper on the bed when also using the PINDA sensor adjustment with the zip tie. Also consider the tension on the belts, try for 250 (lower number -> tighter). Getting belt tension down to 260 or 250 would be ideal, just dont break something. [/b]
See the rest of the discussion and the full thread at: https://shop.prusa3d.com/forum/others-archive--f66/self-test-error-x-axis-length-t13327-s10.html
Publié : 14/12/2018 10:06 pm
