X belt not flat
erin.e.bergman
(@erin-e-bergman)
X belt not flat
Hello, I assembled this from the kit and the x belt is rubbing against the orange piece it ought to just be passing through.
I was wondering if anyone had any quick ideas as to what went wrong here before I start ripping the whole thing apart.
I have verified that the motor on this piece is the x-axis motor.
Thank you to anyone able to help.
This topic was modified 6 years temu by erin.e.bergman
Opublikowany : 27/04/2020 3:30 pm
RE: X belt not flat
The toothed wheel is on BACK TO FRONT! the hub with the grub screws should be towards the end of the shaft not near the motor!
Joan
Opublikowany : 27/04/2020 3:38 pm
erin.e.bergman
(@erin-e-bergman)
RE: X belt not flat
@joantabb
Hey, lookit that, fixed that easy. Thank you so much.
Opublikowany : 27/04/2020 3:46 pm
