X axis slamming extruder into z axis
john.w60
(@john-w60)
Hello, I just built my mk3 and it printed its first print very well! I was really excited and I went to print something else but ran into an issue. The extruder seems to get stuck in the front right hand corner and then the x axis tries to force it into the right z axis. It makes a horrible sound as the plastic is grinding into each other. I stopped the print and then re did the xyz calibration and had no issues there, but now every print that I have attempted since then fails before starting because the extruder ends up grinding into the z axis. After I canceled the most recent print, I went into settings and tried to move the x axis with the dial on the LCD board, but it thinks that it is at the x coordinate "0" all the way in the right corner, so i can't move it to the left and trying to move it to the right runs into the z axis. This is odd to me considering that the XYZ calibration runs just fine and it says the home point has been located successfully even though for some reason point zero on the x axis is all the way to the right. Any suggestions?
Opublikowany : 05/12/2018 4:44 pm
1 ludzie polubili
Re: X axis slamming extruder into z axis
Sounds unusual... what plastic is hitting?
There are a couple of "calibration steps" where the printer finds the movement extremes by stalling the stepper motors. This is safe and harmless but sounds bad. On power-up the extruder is moved to the top of Z-Axis and hits a few times. Then X and Y homes are found - but these are quieter because the belts buffer the impacts. Each "bump" lasts a couple seconds.
If this isn't what you are hearing,
1) Check that the PINDA probe LED is turning off as the extruder gets near the bed. If set too low, the printer can't know the nozzle is close to hitting.
2) Check X and Y movement: Raise the extruder by pressing the control button a few seconds to pop up the X Move option: put the extruder about half way up. Power off and see if the X and Y axis move freely by hand. Is there any catching, tight spots, or is the movement smooth and continuous?
Does this persist after a power cycle? Have you done a hard firmware reset?
Opublikowany : 05/12/2018 5:12 pm
john.w60
(@john-w60)
Thank you for the reply! The plastic that is hitting is just the edge of the extruder casing against the plastic part that connects the x axis to the Z axis. I have done a hard reset, checked the pinda probe, and when it is turned off there is nothing catching the drive belts and it seems to move freely. I have definitely started running out of ideas
Opublikowany : 05/12/2018 6:41 pm
john.w60
(@john-w60)
Opublikowany : 05/12/2018 10:52 pm
The X-Axis "homes" or finds "zero" by contacting the extruder to the motor mount. This is normal. It should buzz for about a second. The printer also slides the bed so a bearing hits one of the rod mounts. This all happens on the left side.
These contacts cause the motor to stall and allow an electronic measure of "home" positions for the printer to work with. Once these home positions are found, the printer can count motor steps to accurately position the nozzle in 3D space.
When you power on the printer - it has no idea where the mechanical zero is, and assigns 0,0,0 to wherever the extruder is. It will only move up, right, and 'back' from there.
When you power on the printer, you normally leave the extruder where it is and select a file to print. By selecting the file (or printing from a computer), the gcode has the commands to home the printer, heat things up, and start printing.
Any of this make sense?
Opublikowany : 06/12/2018 12:23 am
chad.b9
(@chad-b9)
Hello,
Did you ever find an answer to this problem? I have an MK3, but am having the same issue. The printer seems to think the X zero is all the way to the right.
Opublikowany : 10/02/2019 10:35 am
Linda
(@linda)
RE: X axis slamming extruder into z axis
Did you ever get this sorted out? I am having this problem after upgrading my mk3 to mk3s and flashing the most recent firmware
Opublikowany : 04/05/2019 11:17 pm
nathan.s26
(@nathan-s26)
This just happened to me this morning. Kind of odd. So I woke up and the printer was asking me to unload the filament. Which I thought was extremely off since I didn't put in a color change. So I ran through the unloading and loading and the print resumed. A couple minutes after that my printer made a horrible noise. The x-axis slammed the extruder into the right side of the printer. I pressed resume and it did it again. Tried to move the extruder useing move axis and it won't go any further left then center as it thinks my 0 point is much further right. Checked the belts and gears they all seem fine. This is the first time this has happened after hundreds of prints. Has anyone solved this issue?
Opublikowany : 03/06/2019 12:50 pm
NBachman
(@nbachman)
This is most likely one of the x-axis bearings binding. I think they need to talk to their supplier about quality control.
Opublikowany : 03/06/2019 1:22 pm
vintagepc
(@vintagepc)
Posted by: nathan.s26
Sounds like you had a false runout. It has been known to bugger off afterwards and lose its coordinates.
https://github.com/prusa3d/Prusa-Firmware/issues/1522
Opublikowany : 03/06/2019 1:42 pm
Dashy
(@dashy)
I cannot get past "X axis wrong size" error, in the self test to begin printing. Has anyone else had this problem?
Opublikowany : 18/04/2020 3:48 pm
