x axis shift
Dahlia503
(@dahlia503)
x axis shift
Hi everyone,
My prints seem to shift right, when my print is about 5mm tall, then overcompensates and shifts left on the x axis.  I am not sure if something needs to be tightened, adjusted, calibrated, or just slowed down.  Any help would be appreciated.
A couple of notes:  I had the printer sitting for about a 9mo and recently started up again.  It has been moved since I used it last.  Secondly, I switched out the nozzle today.
Dahlia
Publié : 07/11/2021 12:17 am
Dan Rogers
(@dan-rogers)
RE: x axis shift
Do look at all of the other X axis shift threads.  First up, check your grub screws have not come loose on the pulley on the X motor.
Publié : 07/11/2021 8:12 am
Do as @dan-rogers suggests.
If your printer has been sitting gathering dust for a while don't wait for the usual elapsed hours, give a bit of tlc now.
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072
Publié : 07/11/2021 4:37 pm
