X-axis shift
narloke
(@narloke)
X-axis shift
Hi all,
I could not manage to solve my X-axis issue.
I check the belt tension but seems to be ok.
I join the result on Adalinda, plz ... help ! 🙂
I stop the printing to save some PLA 😉
"One man armed with the right word may do what an army of swordsmen cannot" - Robin Hobb NarLoke, Co-founder of Sentry Games
Twitter
Facebook
Sentry Games
Posted : 16/05/2018 1:45 pm
Roy
 Roy
(@roy)
Re: X-axis shift
Pls. also check that your pulleys are tightened.
Posted : 16/05/2018 7:21 pm
narloke
(@narloke)
Re: X-axis shift
Yes there are.
And my firmware is up-to-date :S
Twitter
Facebook
Sentry Games
Posted : 17/05/2018 8:07 am
Tiago
(@tiago)
Re: X-axis shift
See if printer detect any crash at support menu, if so disable it.
Crash detection have caused that to me in the past, since then i have that disabled, they are all false triggers to me
Posted : 18/05/2018 12:08 am
Re: X-axis shift
does the X axis GT2 belt idler pully on the right hand side rotate freely?
there is nothing to prevent you over tightening the bolt and causing excess friction!
is the extruder cable bundle secured firmly with all of the zip ties correctly spaced?
are the smooth bars scratched?or unlubricated?
Posted : 18/05/2018 12:39 am
narloke
(@narloke)
Re: X-axis shift
Thx for the help, I disable the crash detection and it seems solving the issue 🙂
Thx a lot !!!
Twitter
Facebook
Sentry Games
Posted : 21/05/2018 5:22 pm
Tiago
(@tiago)
Re: X-axis shift
Thx a lot !!!
Crash detection is not perfect, but i recommend to check other stuff said by joan.t
Right now crash detection represent almost no benefit, because it don't have a pause or standy procedure, if nozzle crash hard into object and move or detach from bed it will continue to print in mid air. And lets say object didn't detach but nozzle keep crashing, it will keep repeat and rehome. It should be more smart and have a threshold and debounce time defined by firmware or user for pause the print and require user to verify things. The more crash and rehome the probability that layers are misalaigned are higher
Posted : 22/05/2018 12:09 am
narloke
(@narloke)
Re: X-axis shift
Ok thx, I will check that 🙂
Twitter
Facebook
Sentry Games
Posted : 22/05/2018 8:13 am
