X axis layer shifting
Pablo Lereu
(@pablo-lereu)
Hi everyone,
I am a new owner of a MK3S. I completed the kit this week and now tinkering with prints.
I am having trouble with X-axis layer shifting. The first few layers always seem to go fine and then the shifting begins.
The shifting is always from left to right.
I am using the Prusa filament that came in the box.
The filament sticks well with a live Z of -1.100.
I have tried to reduce the speed to 90% as well as 75% but it still happens.
The tension values also seem to be in the correct range.
I am currently printing a 3x6 grid.
Any help on troubleshooting would be greatly appreciated.
Thanks
Pablo
Respondido : 21/05/2019 10:05 pm
Vojtěch
(@vojtech)
RE: X axis layer shifting
This is usually caused by improperly tightened X axis pulley on the X motor. The set screw on the flat portion of the axle must be tightened first, to self-center on the flat and only then the second set screw can be tightened. Anything else will lead to a partially loose X pulley and in shifts in higher layers as the printer increases acceleration compared to 1st layer.
Respondido : 21/05/2019 10:20 pm
