X axis error
chriscott69
(@chriscott69)
X axis error
howdy, just finish  assembling my MK 3S kit , started the testing and got a error saying axis length axis X
need help fixing it please
christopher
Publié : 31/08/2019 9:56 pm
RE: X axis error
Publié : 31/08/2019 10:14 pm
RE: X axis error
ps: X length errors are almost always one of three things: tight bearings from the extruder housing compressing them too much (loosen the extruder housing screws to resolve); bearings that are dry, and need lubrication (the bearings do not come from Prusa lubricated with oil suitable for operation - they need to be packed with grease or oiled regularly); or the cable harness coming out the back of the extruder is too thick, cable ties, fabric sleeve, or loose wires that touch the frame, Einsy case, or power supply (anything blocking the X-axis motion will cause a fail, including loose fan screws, cable tie ends in the wrong position, spool mount in the wrong location, etc.).
Publié : 01/09/2019 8:23 am
chriscott69
(@chriscott69)
RE: X axis error
Thanks got it fixed
Publié : 02/09/2019 7:38 pm
RE: X axis error
What was it?
Publié : 03/09/2019 12:30 am
chriscott69
(@chriscott69)
RE: X axis error
It was the PINDA sensor wire was hitting the frame I just relocated the wire
Publié : 03/09/2019 5:35 am
