X and Y axis Hesitation - New MK3S+
This has been covered many times, so I have checked every solution I have read. The belt tension is good (both are within range on the belt test), made sure the gears are on correct and not right against the motor, loosened the u-bolts, cleaned and oiled the rods, and made sure there are no obstacles or wires catching. Is have put it all together and taken it apart twice now. I am at my wits end.
The hesitation happens in the same place for both axis every time. The x axis is right in the middle moving right. The y axis is at the 66% mark only moving forward. See the video, it is clear on both. What else can I try?
Publié : 22/03/2024 3:00 am
