Wrinkling in first layer only in certain area
mgtarallo
(@mgtarallo)
Hi guys
Not sure why this just started happening - perhaps you can give some insight.
I have 3 Prusa Printers - the same model (GCODE) prints fine without issue on 2 of them.
On the one in question I started getting wrinkling in one particular area. The z-axis is calibrated perfectly. Is this an adhesion issue with the textured sheet. Please see attached pic.
As stated - same model prints perfectly on other 2 prusa printers - should I recalibrate - or is this an indication of the heatbed failing or PEI texture failing and needing revitalizing etc?
Thanks
Veröffentlicht : 03/09/2021 4:09 pm
mgtarallo
(@mgtarallo)
Perhaps i need 7x7 bed leveling?
I think I might have answered my own question - but still interested in what others have to say
Here is what I found:
https://help.prusa3d.com/en/article/mesh-bed-leveling_112163/
I will update once tests are complete.
Veröffentlicht : 03/09/2021 4:22 pm
Dan Rogers
(@dan-rogers)
Comparing printers - not a thing
Couple of red flags - textured sheet = hard to get good adhesions.  2) comparing printers and expecting them to be the same ...  If your first layer is not sticking, you should super-clean your sheets with hot soapy water, and then really go after that perfect live-Z.
Veröffentlicht : 05/09/2021 7:09 am
Mitglied
Wrinkling firs layer
There are two things that can cause this:
  1. The first layer is too low: try the 7x7 mech leveling and redo your calibration.
  2. Dirty bed - clean it with IPA and/or soap and water.
Veröffentlicht : 05/09/2021 10:58 am
