Clean the fan blades. Make sure there is no stringing/fluff in the hub, perhaps touch the hub with a cocktail stick tip dipped into light machine oil (pull back the sticky label on the back, re-stick afterwards.).
Check the fans are cleanly plugged into the Einsy board (pull and re-plug) if still failing check for broken wires with a multimeter.
Opublikowany : 24/11/2025 6:16 pm
