Wizard and Z-Axis Calibration Fail
james.f31
(@james-f31)
Hi All,
I am brand new to the world of 3D printing.  I purchased my Prusa MK3 just over a year ago and I am finally getting around to putting it together.  Assembly is complete, but both the wizard and the Z-axis calibration are failing the same way.  X and Y seem okay, and the machine drives the extruder to the top of the Z-axis as expected. That said, as soon as calibration begins, it fails IMMEDIATELY when driving the extruder *down* the Z-axis.  Like, it moves a few mm and fails with the following error:
"Calibration failed! Check the axes and run again"
I have a video that I will try to post showing the exact problem.
Firmware has been updated to 3.9.0.  Obviously we did something wrong in assembly, but I have no idea where to start looking.  Anyone ever seen anything like this?  Any ideas where to begin?  Many thanks in advance -- I can't wait to (finally) start using this thing!
--Jim.
Questa discussione è stata modificata 6 years fa 2 tempo da james.f31
Postato : 29/08/2020 3:14 pm
GKMAKEIT
(@gkmakeit)
RE: Wizard and Z-Axis Calibration Fail
Try loosening the two screws on both sides holding the trapezoidal nuts on just to the point they can move with a little resistance, try the Z calibration again. If it works move the Z as high as possible then tighten the screws.
Postato : 29/08/2020 6:33 pm
james.f31
(@james-f31)
@gkmakeit
Thanks, I'll give that a try and report back!
Postato : 29/08/2020 9:31 pm
james.f31
(@james-f31)
Well, I promised to report back...but I am more than a little embarrassed to do so.  The issue was...wait for it...that the PINDA probe cable never got plugged in to the board.
Um, yeah.
From inauspicious beginnings?...
Postato : 31/08/2020 7:45 pm
GKMAKEIT
(@gkmakeit)
Glad to hear you figured out the issue.
We all have those moments!
Postato : 01/09/2020 12:33 am
