Wiring for print fan cable?
TT
 TT
(@tt-4)
My MK3 print fan is failing the self test. I'd like to test the cable and fan with a batter to make sure it actually works. Can someone tell me what each wire does, so I know how to connect the battery. Also, what voltage is the fan?
Postato : 22/08/2018 7:50 pm
Re: Wiring for print fan cable?
Black wire ground / 0volts
Red Wire 5 volts
Yellow yellow - tachometer, pulsed output from fan...
Postato : 22/08/2018 9:13 pm
1 persone hanno apprezzato
TT
 TT
(@tt-4)
Looks like Prusa sent me a defective fan. The black wire detached itself from its base. I can't even solder it on because the underlying metal was ripped off with it.
Postato : 23/08/2018 4:41 am
gatonini@zoominternet.net
(@gatoninizoominternet-net)
Great picture Joan !
Postato : 25/08/2018 3:54 pm
I stole it off the build site
Regards Joan
Postato : 25/08/2018 4:39 pm
I put it on my desktop 😀
Postato : 25/08/2018 5:24 pm
Lucent
(@lucent)
RE: Wiring for print fan cable?
Same problem here. Did you find a solution other than replacing the entire fan?
Postato : 29/03/2024 11:04 pm
