Whats the best method to replace a bearing in the extruder assembly?
ben.t7
(@ben-t7)
I was doing some general maintenance on my printer today since I couldn't fall back to sleep and noticed that I had some grooves worn into one of my rods. I got a replacement coming but I am going to replace the bearing as well just to be safe that it isn't bad. I am just not sure what the best approach at getting to it with out tearing apart the extruder assembly to get to it.
Opublikowany : 01/06/2018 12:43 pm
Re: Whats the best method to replace a bearing in the extruder assembly?
The linear bearings are secured by the X axis rear panel and zip ties.
There is no easy way to change them
Regards Joan
Opublikowany : 01/06/2018 2:40 pm
