RE: What causes my needle holes?
It looks to me like the result of using 'random' seam position. If so, try setting it to 'aligned' or dictate exactly where you want the seam (you can paint in the seam position in PrusaSlicer 2.3 🙂
Opublikowany : 31/10/2020 10:08 am
I don't know what else to call these. They actually look worse in the picture than they do in real life, but does anyone know what would cause these little pinholes in the layers and what to tweak to tune them out?
you can set the seam position in prusaslicer here. i usually use aligned:
Opublikowany : 31/10/2020 1:51 pm
