what allen key to use at heater assembly ? suspect that rounded off by users
Jason
(@jason-5)
Hi all,
we have a prusa i3 Mk3 set up in our lab.
one of the users "semi" dissembled the nozzle assembly because of a problem (extruder nozzle is blocked i think)
i suspect they could not get the allen key screw loose (see pictures below) and then desided to include me to the whole thing.
my question is that i want to make sure i use the 100% allenkey size. I suspect the "rounded" off the allenkey screw hole.
it feels to me that i should use a nr2 allen key. as far as i could see in all the available documentation only metric screws are used.
can anyone help me out to tell me what allen key it should be ?
Cheers,
Jason
Best Answer by JoanTabb:
2mm for the dome screw
1.5mm for the thermistor grub screw
Joan
Napsal : 14/01/2021 10:26 am
Jason
(@jason-5)
RE: what allen key to use at heater assembly ? suspect that rounded off by users
maybe my message was to long and to omplex for my simple question (sorry I am special 🙂 ).
my question: what allenkey size to use in (black)screw shown in picture(s).
Cheers,
jason
Napsal : 14/01/2021 10:43 am
krom
 krom
(@krom)
I have not disassembled the Heat Break yet, but this might be helpful to you:
https://help.prusa3d.com/en/article/hotend-disassembly-heatbreak-stuck-in-the-heatsink_112677
which leads to:
https://e3d-online.dozuki.com/Guide/V6+Assembly/6
And yes, the screws are all metric. That guide above mentions a 1.5mm Hex Wrench.
Which one it is exactly of the wrenches supplied with the printer, I cannot say. I'd go for one that fits. 🙂
Hope it helps!
Napsal : 14/01/2021 11:18 am
IPIND 3D
(@ipind-3d)
Yes, only metric Allen fasteners are used.
They REALLY need to invest in some silicone socks to look after the heater blocks!
Napsal : 14/01/2021 12:55 pm
Joan
Napsal : 14/01/2021 7:13 pm
Jason
(@jason-5)
Thanks everyone for the information.
I will try to mark this post as solved.
thanks again,
Cheers,
Napsal : 15/01/2021 9:54 am
