[Solved] Weird sound from printer.
Mike
 Mike
(@mike-56)
So this is my second printer, first Pursa.  I have printed 3 objects so far and they are amazing.  Needless to say when printing (even on the first few layers) I get this squeak.  Is this normal?
Napsal : 02/05/2019 2:22 am
Mike
 Mike
(@mike-56)
RE: Weird sound from printer.
I know no one has had a chance to weigh in yet, due to my post needing approval (i assume because this is my first post) but I believe it is the spring on the screw that holds the idler door shut or the idler itself.  At least that's where I think the sound is coming from.
needless to say, prints right now are looking near perfection, should I tighten it?
This post was modified před 7 years by Mike
Napsal : 02/05/2019 4:09 am
gkPrints
(@gkprints)
If you mean the squeaking sound while retraction, it's the gear inside the idler. I didn't have this in the beginning then adapted something and I got this squeaking. Just play around with the tightness of the screws. That's what worked for me at least.
Napsal : 02/05/2019 3:05 pm
vintagepc
(@vintagepc)
Make sure the rod in the door is still centered in both ears. It causes squeaking if it is not.
Napsal : 02/05/2019 5:10 pm
Also - there are instructions on the Bondtech site that say the bearings provided with the gear set are to be lubricated before installation.
Bondtech Filament Drive Gears
A Lithium based grease is recommended to use on the gear section and inside the needle bearings for low friction and to avoid wear. A small dab of grease is enough.
Napsal : 03/05/2019 5:45 am
Mike
 Mike
(@mike-56)
So I opened the door checked the alignment....Looks good
put the tension screw back in but did not set it as tight as it was last time.
Before: Just about a full rotation past flush
Now: Just about a quarter rotation past flush
Thank you guys for the help sound is gone now.  Hopefully, I didn't cause any damage.  I prolly printed about 50 hours or so before the fix.
Napsal : 05/05/2019 5:19 am
