Weird LCD behavior MK3
Christizzz
(@christizzz)
So... i ahve been having some werid behavior with my LCD
1) the screen flickers when it is printing and when it is on idle.. here is a video showing this flicker: https://drive.google.com/open?id=1FCD4KI_knWb5RYr5cKG9GhpJK-c9VO19
The flickers happens every 10 seconds ( i timed it..so it seems clocked..)
the flickers was happening on 3.3.1 and it still on 3.4.0.
2) when printing using the SD card, when print finishes, i get weird symbols ( the hot end symbol disappears, i get a "° "symbol after the Print Done Message and some "##" and i need to reset the printer in order to get back the normal symbols... i did not notice this happening when printing using Octoprint... i checked the cables... i checked the connections.... didt notice anything... i mean i tried to move the cables to try and trigger it but nothing...
PS: this is my 3rd screen: the first one had dead pixels, the second one was not booting correctly. this one is perfect... just these issues.... the flicker issue was present on all 3 screens... I dont know abt the screen symbols since i was only printing using octoprint.
Thanks
Opublikowany : 13/09/2018 9:02 am
Walter E
(@walter-e)
Re: Weird LCD behavior MK3
i also have this flickering every 10 seconds.
is this normal? has there been a solution for it?
best regards...
Walter
Opublikowany : 01/01/2019 4:45 pm
paul.s61
(@paul-s61)
I have the same flickering but I thought it was normal or is normal.
Opublikowany : 01/01/2019 11:41 pm
thrawn86
(@thrawn86)
100% normal
Opublikowany : 02/01/2019 1:01 am
